I’m not sure if this has been done before, but what I’m going to do is a “write up” on this very common problem so hopefully it can be used as a reference in the future.
Problem: You have a lot of water in your car, appears to be coming in through the hatch somehow. I noticed this when I was driving after a big rainstorm and I heard sloshing that definatly was not the gas tank.
Diagnosing:
Tools You’ll Need:
A watering can- Those green plastic things your mom uses to water indoor plants.
Basic tools (screwdrivers, you know the drill) no pun intended…
A flashlight
A friend
Step one: Remove a few interior things: Hatch cover, Carpet (just pull hard on the snaps and they will release from the rear seat) and the rear plastic panal.
Note- These interior panals seem to be the bane of everyones life. They don’t have to be that bad if you just understand them.
On this rear piece, unscrew the 3 screw/snap things (idk the official name) on the bottom. To do this: Unscrew this + a ways, and then grab and pull up. Set aside. I broke one doing this, no biggie.
I think there may be screws inside where the rear taillight access is? I can’t remember. Just pop those things off and take a look.
Once you decide you’ve removed all the screws, simply give it a good hard yank STRAIGHT UP. it will pop out, and if you pull straight up, you probably wont break anything.
Step Two: Park your teg in your driveway. If your driveway is slanted downwards, then pull straight in (so the rear of the car is lower than the front) If your driveway is flat, no biggie.
Now open your sunroof. Along the sides you will see little “canals” of rubber. Go fill your moms watering can, and SLOWLY pour water into the canal, (diagnose one side at a time.) Have your friend stand behind your teg and watch for water. If your tube is plugged in, the water will run out by your mudflaps kinda. If water is coming inside your car, then stop.
Repeat on the other side.
Now you have established which, if any, of your tubes are unplugged.
Step Three: On the side(s) you have water coming in:
Remover your rear speaker cover thing. Just three + screws. Easy. Now remove your rear speakers and set them aside.
Working from the rear, undue screws and stuff until you can pull back the panal to see what is underneath. NOTE- unlike the rear panal, these need to be pulled STRAIGHT OUT or you’ll break the connectors. Just give a hard tug straight towards you and they’ll be fine Have the friend hold it back for you while you take the flashlight and find the tube itself. It’ll be kinda a nastly clearish yellow color, about 3/4"-1" in diameter. Once you’ve located it, pull softly upwards. If the tube is unplugged, you will be able to pull it right out. If not, then its plugged in and you’re diagnosing the wrong problem.
If you establish that the tube is free- follow it down with your hand to where it stops. Now feel (or look) around and you’ll find a rubber “female” end (the gromit). Once located simply plug it back in.
Once plugged back in, go back to the watering can and pour more water down the canal. If you fixed it, it’ll run out the car by the mudflaps, and you’ll have no water in the car.
Note- The passenger side is about 100 times easier than the drivers side! On the drivers side the power antenna makes the job very difficult, and you have to undue some screws and jam it sideways (to the right, towards the front of the car) to gain access to the tube. I also seem to remember removing the rear speaker bracket thing (plack plastic) That thing is a b!tch too.
Step Four: Obviously, replace your interior (after you dry it out!) Check your rear seat. It is made of foam, and if you drove at all with this problem, it is likely your rear seat (bottom piece) is wet!
If both sides are leaking, start with the pass. side to gain experience.
Sorry this is so long, but its detailed and some people like that.
Total time with minimal experience with cars and two unplugged tubes: 3 hours at a relaxed pace. I’m serious about the firend though. 2 people doing this will cut your labor time in half.
Good luck!
