sunroof noise
when I open my sunroof, it sounds normal. when I close it, there is this weird clicking/grinding noise. what’s the diagnosis?
does it sound like vibration? that is a common problem in our tegs. there is a teg tip to get rid of that. I find that opening the sun roof and pulling up on the silver metal bar with the rubber attached to it before closing makes a better seal (you will hear) and then it won’t vibrate.
but you can also follow the teg tip to permanently rid the situation.
does it only mae the grind when its all the way closed? CUs that is just the motor still trying to close it when it can’t move any father.
my sunroof also makes that noise when it’s all the way closed, so i figured it was just the motor still trying to close it.
does anyone have this problem: my button for my sunroof is backwards i think… the picture of the filled in white car opens it, and the pic of the car with the roof open closes it, anyone else have this prob ? i checked the wiring to see if it’s backwards, but the harness only goes in one way.
