Hey my sunroof dont work and i wanted to know where is the relay located @??
hmm
Does any1 knows where is it??? :sad:
did u check the fuse box? maybe you blew a fuse?
Yes my fren did everything look good…
Mine broke too, so i took it all apart searching for the problem. Mine was inside the button. Get a really thin knife or screwdriver and pry on the side of the button until it pops out, that is unless you want to take the whole dash out. Inside the button are two little arms that push down little peices of metal when you push the button up or down. One of the arms might have broken like in mine, but there are lots of little pieces that could have come loose or broken inside. If you cant fix it try getting a whole new button from the junk yard or off ebay maybe. If thats not it I dont know what to tell you.
the relay might be on the wiring in the headliner… i have the compelte wiring harness laying around somewhere… if you need the relay let me know
fix
thx 4 all ur help… =) is fix already
What was the problem?? mine stopped working… was working great before I stored the car for the winter and not it doens’t work anymore…
i’ve got a sunroof wiring harness (minus the map light wires that I cut off for another member) including the relay. I have the motor too and could pack it up and send it your way for $15 USD. Let me know
Thanks man! I’ll do some troubleshooting on friday and let you know if I need anything!
Got it working! it simply was the fuse that wasn’t making good contact… I bent the connectors a little and everything works great now!
Thanks for the offer!
