Can someone please tell me what the part # is (Acura or Honda) for the moonroof switch located in the dash? I have a 90 GS teg.
Tried the tip for cleaning the switch contacts but that only worked for a short while.
Thanks, Pat
Yo- Can someone out there with a parts list answer this?
Pat
i need it too. same problem. by the way, is there anyway to take the switch out from the front of the dash or do i have to pull off the black plastic surround?
Re: Sunroof Switch part # ?
Thanks, Pat
25239- if you haven’t found it already. (at least thats what it says on this site) Acura Models | Acura Automotive Parts
CJSLS Thanks, Just replaced the switch and it works great. Thought for a long time that the motor had gone bad and was expensive to replace then talked to a honda mechanic. He said that the motors rarely fail. Less than $50 total for the switch and all is well. Come on springtime.
Pat
