I saw a da with some supppperrr bright yellow fog lights. i want these…how much do they cost and what are they called?
Most likely JDM One Piece Headlights. search for them here on g2ic
i dont want to change my whole head lights tho…would i have to in order to get these really high yellow fog lights?
what headlights are you using? they probably removed the glare guards and by doing that shows a lot more light.
No, there are some SUPER YELLOW bulbs that password:jdm offers that should suite your needs. www.passwordjdm.com
I’m not sure what kind of bulb the foglight is, but look that up, and order up a replacement set in super yellow.
Just so you know, those aren’t the bulbs for the fog lights. The fogs use H3 bulbs, Not H4.
:getsome::manual:
Figure that out!
I removed my fog glare guards, and I bought these real cheap off of ebay. They are like PISS yellow. I’ve had PIAA bulbs and they were not as yellow as these are.
I’m gonna toot my own horn since your in TO and so am I.
It may have been my car you’ve seen. In which case I have JDM 1 piece headlights and H3 4000k HIDs. I have however, now sold the HIDs.
thats what i was going to say…4000K HIDS thats what i have too and they are sexy!
how hard is it to install ?
and about how much woudld it cost for a 4000k hid kit?
and glare gaurds??? lol i know im n00b…but whats that
i thought yellow was 3000k
[QUOTE=Wylee_M;1972455]how hard is it to install ?
and glare gaurds??? lol i know im n00b…but whats that[/QUOTE]
It’s plug and play so not too hard to do.
Glare guards keep the light from glaring.
Correct but JDM 1 pieces have yellow filters in the fogs. I have 6000k in the headlights and wanted something less blue in the fogs, hence the 4000k.
Take out the fog housing (one 8mm bolt), unplug the bulb etc…there is a square metal thing right inside of the housing, that is the guard. If you want to it out, there is this really simple way of doing it. Take a long flathead screwdrive and a hammer, line up the screwdriver where the guard screws into the fog housing and pound both of them out, the guard will fall into the housing and you can bend it with your fingers so it’s small enough to pull out of the opening of the fog. I’ve done it to like 4 sets of fogs, it’s very easy…takes only a few minutes.
fog lights
i was jus wonderin has you jus got the foglights on by itself. wen i put mine on the headlights have to be on in order for the fogs to go on.
thanks for your time lmk
Look in the TEG tips, fog light rewiring.
