Suspension/brake overhaul
ok i’m getting in some new coil overs, and gonna do a basic over haul i think, probably gonna need at least a front camber kit so wondering whats the best/most affordable to pick up.
also what should i replace as far as bushings/joints etc.
was thinking, front lower ball joint/and bushings, tire rods,
for brakes i’m gonna do rotors/pads all around, but the real question i have is when i first got the car i replaced the front rotors and rear pads. the front pads were brand new with the car and the rear rotors still looked good.
the passenger side in the rear had the ebrake disconnected looked to me like he lost the pin or something so i put it back together. ever since then when i brake theres an awesome grinding/rubbing noise like my pad is shot, however when i checked my rear to see, the rotor is actually surface rusted over with a few little lines that are shiny.
i’m assuming its binding and not actually clamping down other wise the whole rotor would be shiny, just wondering if this is common or not, i’ve searched and just see people say take it apart and look at it but its 30 degrees outside so i don’t feel like pulling it apart yet lol.
basically looking for suggestions on:
front/rear camber kits
what parts i should replace when i install my new suspension/brakes
what to do about that rear caliper
For the camber kit go wit skunk2.:werd:
yeah thats what i was thinking, gonna order some gc extended top hats this week i think, and gonna grab front/rear pads and rotors and probably upper/lower balljoints/bushings where needed since i’m planning on getting new skunk2 uppers for the front and some new lca’s for the back
