:bigread: whats up g2ic this is my first post and well i need some help deciding on a suspension for my DA. Im looking for something comfy yet trackable good for the strip or road racing. any suggestions? adjustabilty is a must thanks for the help=):bang:
any help? im kind of leaning towards the ground control/koni yellow combo but i would like some feedback i was also considering some sort of one piece coilover setup. This is my first build on my car and im kind of new into this so anything you suggested will be looked into.
Ground Control/koni set up with extended top hats is one of the most respectable setups
Alright Is it a comfy ride? im looking into it
I have that setup on the “street” springs and no complaints about the ride.
koni/gc is one of the most respectable setups but save yourself some bucks and go with this.
out of the many suspension setups ive rode in or drove, these were the best for the dollar amount. highly recommended and if you search online you can find them a little bit cheaper at other places. usually around 550. top notch customer service also.
all depends…im thinking of going with d2 racing…but i might just end up buying stiffer springs from ground control…i have the ones off the shelf! depending on what spring rates to run though
