is there anyone did a suspension swap before ??
im talking about using DC2 (94+ integ) or 92-95 civic into a DA??
i’ve read an article somewhere in this site written by Loc about the swap but didnt give the details i want to know…
:bored:
thanks alot man! i think that could help me out!
well I was considering using shocks for a 94-01 Integra/92-95 Civic as well when I upgrade my shocks.
From what I could tell the back shocks would bolt right in, but they are a slighty shorter body, but for the front you need the shock forks cause the DC2/EG front shocks are fatter.
HTH
Don’t you need the JDM LCA’s to make the DC shocks work?
I thought it was DC/EG front forks and JDM LCA’s. Maybe someone can clear it up.
TIA
I am planning on getting a set a itr apex N-1’s on my teg. But that won’t happen anytime soon since my timing belt just broke again. :uhoh:
Awsome, thanks.
thanks for ur attentions guys! but i still have some stuffs that i dont understand.coz ihave already tried the swap but there’s some problems occured.
i was taking out the whole front suspension assembly from my friend’s 94 integra(from drop fork,shock,spring and upper mount as well and put it in my 93 gsr…evrything went in perfectly but after that, i realized that the drop fork from the DC is not as wide as my DA…so when i fully turn my sterring wheel to one side, the drop fork would scratch my drive shaft!!
some pple say that i need to change the lower control arm to a jdm one…which i didnt…is it that the problem? but why need the lower arm when everything fits in…?
