So after driving to GAT and back home this past weekend. I believe my DA is due for new shocks & struts.
The ride is currently too bouncy. Although she did handle the roads on the smoky mountains and newfound gap really well. Better than I expected. I also want to go lower a bit, not too much though, while also getting some performance upgrade.
So far I’ve been given the suggestion of getting Koni yellow shocks with H&R OE Sport Springs or H&R Sport Springs.
Send me some suggestions or what you’re currently running. TIA!
What’s Gat? I’m currently running koni/gc with extended tophats, st rear sway bar, hard race camber kits, toe arms, rear lower control arms, rear trailing arm bushings and prothane front shock mount bushings
It was a huge car meet in Tennessee this past weekend, hosted by slammedenuff. They call it GAT cause the city the event is at is called Gatlinburg. Was a great time till it wasn’t. A lot of irresponsible people just have to ruin the good stuff. But thank you for your setup. Going to look into some of those parts and see what I can use that will fit with my current wheel/tire set up.
