Suspension
I have a 90 teg rs, and I am looking to redo my suspension…help me out Im getting springs, struts…what else am I missing???
Re: Suspension
Depending on how low you’re going to drop it, you’ll most likely want a camber kit.
it all depends on how all out you want to go. there is a lot that can be replaced:
-springs
-shocks
-camber kit (if you go low enough)
-stickier tires (this will increase handling more than you could ever believe!) Lower profile can help too.
-sway bars (typically the rear is more important, but don’t overlook the front)
-various bushings - there are a lot of suspension bushings out there. They are made of urethane instead of the softer stock rubber. Some of these bushings are probably due for replacement anyway (like the rear trailing arm bushings). But replacing the other stock ones, even if they aren’t worn out will also increase the handling ability of your car.
