i am in the process of installing a monster tac. and didn’t want to hook the wire into the blue wire on the distributor so i found a blue wire with the same guage that was right by the firewall and i took a risk and connected the tac wire into that wire…but the tac then moved up to idle…but when i reved it was delayed and got a real weak signal and wasn’t accurate…i was wondering if that was the wrong wire…or why the signal was so weak…should i go ahead to connect to the wire coming right out of the distribitor…is that the only way? any help would be appreciated…
thanx,
Dan ![]()
Connect it to the rpm wire that goes into your ecu. You should be able to get a good connection there.
what color is that wire?
later,
dan ![]()
