Yo whutz good I need help since summer my car would stall out once it got hot suspected bad icm so I finally replaced distributor but now my car will not read more than 100 to 200 rpm on my tach checked spark orange and very weak while car is running also when I press the accelerator the car bogs real bad and sometimes dies like its out of time real bad but timming is dead on no codes tps is good and reading correct any help would be appreciated thanks
uhhh… so your car is bogging, right? check your plug wites and make sure that you put them back in the right order. also, take a look at the distributor connectors to make sure that they are seated correctly. hope that helps. good luck!
Thanks yeah I checked my firing order #1 is in the back @ the bottom #3 back but on top #2 in front on bottom and #4 in front on top? But if my firing order was incorrect would that cuase my tach to only read 100 rpm? And cuase a very weak spark this problem happend with the old and new distributor checked and this problem would be icm related too but I know the icm is ok maybe its a wire problem or ecu?
i see… did you check to see if the distributor rotor was firmly in place? do you have access to another distributor? why do you suspect the ecu wiring? have you done anything to the wiring before?
