tachometer
hey just wondering if anyone has ideas of what type of tach to go with I don’t want some giant ricer thing… I need something that at least goes to 9000 the reason for this is I am swapping a b16 into my car
you can get the auto meter shift light that doesnt use the tach. or the apexi tach is slim and smaller than the auto meter tach.
yeah i will check those out thanks
y don’t u just get a jdm cluster, goes to 9.5k and looks stock…
i dont think your B16 will red line at 9K… i’m fine with my stock LS tech., goes up to 8K and that where it redlines…but, eh, some people want to see more than 8K on thier tach…
I agree with Stealth DA9.Just get the JDM cluster and you have 9.5k on the tach plus the added JDM look.
Is there any way to change the mileage on the cluster? Most DAs I see have more miles than mine.
you mean roll back your speedo… there’s a way but i don’t know how to do it, theres a certain pin you got hold in order to roll it back…
theres a real easy way…
heres the back of the speedometer
take off the screw that i circled in red… take off the bracket and take out 2 green gear things that are perpendicular to each other. you might have to slide one out before you can get the other one out that attaches to the odometer directly.
after thats out your odometer will spin freely.
what i did was i took a dremel with the circular polishing wheel. and i slightly touched the green gear of the odometer and it rolled back pretty quickly.
assembly is the reverse
ummm… pretty sure thats very illegal
my red line apparently is 8200 i dont have the motor in yet i just like knowing were i am at
wtf? you’re not rolling back the mileage to hide the true mileage of the car. you’re rolling it back so that if you do get another cluster you could match the mileage thats currently on the car…
anyways it wouldn’t really matter since our cars are exempted for the milage, the DOT don’t even record it anymore… only need when you sell the car…
or you could just swap out the speedometer into the jdm cluster.
ProShift, I have a OEM USDM GS-R cluster for sale. (reads in MPH)
It redlines @ 8000 and max out @ 9000
e-mail me if you are interested.
