Tail light brightness
Hhen I hit the brakes, the left side tails light up really bright and the right side is dim, and the left light on the right side flickers on and off. Ive tried swapping bulbs to see if it was that. No wins though. help plz? ALL I can notice is its on the red( bottom) side.
ite… So i went out there today and cleaned the connections on the lights. Then i broke the positive line off the soldered bit on the inside of the lower left light. Any suggestions on how to remove the housing off the socket or should i attempt to solder inside it. Im dreading the ladder
soldered the wires back in. Then noticed i had a wrong bulb (some 1— type bulb) that was causing issues in the circuit. im done here
