Tail light remain on.
Sup guys, well i put a battery in my shell today and the tail lights where on. The brake was not being pressed or anything. Wat do u think it is?
by any chance did u replace ur bulbs…i had the same problem…and found out i placed a wrong bulb in there…your wires may be crossing…
you need to be more specific. tail lights being on meaning the parking lights? first click on the light switch? or the brake lights?
if its brake lights, then check the brake light switch at the brake pedal and see if the plug on the pedal came off, causing the switch not to be pressed in.
nah i didn’t replace my bulbs. I tryed turning off and on the light but there were still on, even the 3rd brake light was on.
Try searching, I had the same problem.
There is a rubber piece attached to your brake pedal that turns off your brake lights when the pedal is not being depressed. These get old and disintegrate. You can either get a new one, or rig up something. It’s really easy.
I used some tape and a penny :ghetto:
Yeah I used a nickel, and taped it down. Havent had a problem since.
Thanks guys. Now if sumone helped me with my sunroof problem i would be in business.
