take off window trim?
I have to take off all my window trim to paint my car and was wondering if any one could explain how pics would be really great thanks!
the Lower piece just slides forward the upper piece is not at all easy to get off in fact the oem piece is ment to go on the window before its installed into the car.
its really hard to get them off with out atleast breaking the clip in the back lower corner. I would advice your find a couple of wreckers and practice on those. bear with me, its been a while but IIRC. start on the very lowest portion of the trim. get a puddy knife and slip it between the paint and the trim, use a rolling motion away from the body as you pull out on it, just keep working your way up the window, its the next clip i believe thats the one that will break but they get easier as you go up.
Good luck
thanks man i actually got all the trim off tonight it wasn’t to bad i only broke the lower clip on the driver side back but oh well i just hope it wont show when i get it all back on lol.
most body shops just use some sort of adhesive if it does.
The Bastards… .:slight_smile:
