My Teg is running very rich (heavy smell of fuel when car starts/idles and bigger than normal puff of black smoke during hard acceleration) and now when I start my car, I notice a little bit of white smoke coming out the exhaust
before I spend more money on goodies for my car, I want to get it back to running normal.
sounds like the valve seals are going bad
that might cause u to be leaking oil into the cylinders
if youre running rich and dont have fpr it might be your o2 sensors going bad
Originally posted by relentlessg2 if youre running rich and dont have fpr it might be your o2 sensors going bad
that’s pretty much what I figured.
also, I failed to mention that the white smoke appeared after using up a gas tank w/ STP Fuel Injector Cleaner (used it bc a while back, another member stated it work fine for him, guess not for me ) anyways, I’m on my 3rd tank of gas after using the cleaner and my car is feeling weak compared to how it was prior to the injector cleaner :sad:
