HMM, This is similar to my problem. Anyones input on this would be much appreciated. I first discovered this when I went home on my lunch break. I cut my car off and remembered i forgot to get ciggarettes. There was 5 second gap in time between when i cut my car off and then cut it on again. It started up (engine was already at operating temprature) and then rpm’s went down down down, until my car just cut off. THis whole process was about 5-6 second between when i turned my key, to when the engine started up and died. After that, I tried to cut it on again and the engine would just turn over and turn over (this same thing happens if i stall out also). Tried it again, and same thing. I had to wait about 30 seconds with key out of the ignition, to where it would start up again (again, same thing will happen if I stall out)
And this will happen to me all day. Ive tested. But it IS hit and miss. For instance, if i go into a store, im in there for a bit, it wont happen when i try and cut my car on. But like tonight, when i tested it. I cut my car on, let it idle down, then cut it off. Then about 5 seconds later i cut it on again, still didnt happen. Tried that process again, and then it did it.
None of my hoses are cracked and the bolts around my IM and FITV are tight. No air is being sucked from the bottom hole on my TB, but when i plug up both my car DOES stall out/shut off. So I am guessing it is my IACV?? I want to be sure. Its a strange problem. Im going to try the white plug thing tommorow and see if that helps any, Also going to seafoam. What else is something i can try? Intake/Injector cleaner im guessing?
EDIT: Ok, so I just did a test. This is what my RPM’s do.
Running temprature test:
Upon cutting the car on at runing temprature, the rpms from start go like this - 1 notch below 2k for 1 second, down to 1k for 1 second, 1 above 1k for 1 second, then 1 below 1k where it idles at. (this is pretty much a representation of how my car always starts up at running temprature)
I then took the car for a spin. Upon returning to my house, I cut the car off, waited 10 seconds, then cut the car on. RPM’s immediatly went to 2k then car cut off immediatly. No stuttering, no sputtering, just died. I then couldnt cut the car on in about the time it took me to take a piss. when i came back and cut it on, it worked.
I will post my cold-start RPM’s in the morning when i wake up.
