[u]DISCLAIMER[/u]
USE AT OWN RISK!! I will not be responsible for your actions. This is a guide, and as such, may not be 100% correct.
[u]CREDITS[/u]
Once again credits come first:
LL Cool B - For using his car as a guinea pig ![]()
N FUL FX - For allowing non-G2 owners post things like âIgnition Timing Check & AdjustmentâŚâ in his website ![]()
[u]NOTES FROM THE AUTHOR[/u]
NOTE: Because this post is too big, I have chopped it into segments.
I personally believe that the current Teg Tip submission for fiddling with the Integraâs ignition timing is well explained. However, it can be improved upon IMHO. Therefore, my version of this Teg Tip will be more of a supplement to the first.
The first Teg Tip actually shows a good example of the 3 dash marks etched on the crank pulley for timing reference - I strongly suggest that you read that, and pay close attention to the figures shown in that writeup.
In this article, I will not go into any detail regarding octane requirements, whatâs good, whatâs bad, etc. I will stick to only what needs to be done in order to check & adjust your ignition timing. I will actually do a full writeup on octane ratings and how it affects G2 Integras soon which I would like for everybody to share their thoughts on. I just would not like to discuss that here.
[u]INTRO[/u]
Task: Check & Adjust Ignition Timing (or Advance Ignition Timing - for the people that use the search buttonâŚhehehehehe).
Difficulty: Easy
Cars Applicable: 90-93 Integras (RS, LS, GS US & Canadian models) - more particularly, cars fitted with the B18A1 engine. It MAY apply to GS-R models fitted with the B17A and/or cars fitted with the B16A 1st Gen.
Car Used in This Guide: 1992 Integra GS 4dr. Auto w/a B18A1.
[u]Tools Required[/u]
- 12mm box wrench
- Jumper Wire (Paper clip will do)
- Inductive Timing Light
When it comes to the Timing light, you donât have to go fancy. I bought mine for $55CAN which was the cheapest available. You may opt to get ones that come with Tachometers, but since G2 Integras come with a factory Tach., you donât really need to spend on anything more fancy.
