i hate u i cant find 92 trunk and tails anywhere
lol, I have two. If you want them bad enough I can take them off the parts teggy!
There has been work done.
Took apart front end earlier this week. Finally got my friend to press in my brand new bearings and replaced all studs while we where @ it.
So after the old suspension was taken out, I started the steering rack and the subframe was gross and greasy. So out it came and I spent a good hour with a hose, degreaser, and toothbrush. Then we sanded the areas with the paint chipping and we painted the thing. I didnt go all out Glynn style but Im happy with it.
And the new manual rack in with spankin new inner tie rods and boots that are NOT torn!
Also we touched up Innovative traction bar(My favorite part from the parts car:naughty:) and cleaned and sprayed the forks with roll bar paint. They actually turned out pretty well I think.
New lower balljoints!
And everything ready for install.
Damn guy! Looks like your car is coming along great!!
Thanks, man. Im getting impatient! lol.
Had the day off (kinda.)
took care of other stuff, but i did clean up the dirty RS wheel I have.
Fodo fodo
Hell yeah man! Looking great! I like the way you mounted the sway bar, I should of though of that and just bolted the whole assembly in!
Any new updates?
[QUOTE=Deceptakhan;2214981]Hell yeah man! Looking great! I like the way you mounted the sway bar, I should of though of that and just bolted the whole assembly in!
Any new updates?[/QUOTE]
Thanks Carl. As a matter of fact there are some updates. As you know Robi and I went over to Glynns to grab some pressure plate bolts and low and beholdz! A teggy BBQ. Why where we not invited Glynn?:rant:
In all seriousness tho. Thanks for the clean bolts Glynn. Thanks to you we where able to accomplish all this:
Clutch and Flywheel.
The GSR stock flywheel and the ACT:
The Flywheel bolted up
The Clutch
Without Pressure Plate bolts we test fitted the RMF header
And Another
Thanks for coming through Glynn!
We actually kinda put the trans on drunk so pics may suck. They looked good @ the time. lol.
Also put on the Innovative Auto to Manual Mount
looks realy good so would u ship the trunk and tails to ct
So I just need a few more things for the motor. I still need to order the jumper harness, which I will do tomorrow. Also need that cover for the bottom of trans, and some other little misc. parts. Tomorrow I will wrap up the suspension, had a problem with the new wheel bearings. I dont know if its the hubs or the bearings themselves where pressed in wrong, but theres too much play. So before the parts teggy was scraped I pulled the knuckles and Ill just run them for the time being. :sad:
You know I just might for the right price. Give me your email and I will take detailed pics of the lid and tails. I think the tails will need new gaskets.
jeffrey.lozano@yahoo.com and were did u order the bearing for the flywheel or did u use the stock flywheel one i need one for my lightwieght flywheel
Ill try to get those pics out to you tomorrow. I just used the stock bolts.
no i mean the bearing for the flywheel the lipot bearing i think its called its were the spindle goes on
Ohh! Sorry. A brand new one came with my clutch.
o ok damn
