ECU chip for 92 gsr…
http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&item=1848913909&r=0&t=0
thanks
david
thanks
david
personally, i’d stay away from it. First off, the power claims they make are outrageous! So, don’t believe that for a second. and to top that they don’t even fill you in on what program it is.
member IVE recommended to me www.hyperducktuning.com for $49 you get 2 different programs and all the needed parts to install it (however you would probably want someone with some experience install it for you). They have other deals too.
if you buy that chip off ebay you will have to buy extra parts to so that it can be installed and you’ll still have to have someone do the install for you.
hyperduck also has a deal where for $89 you send them your ecu, they do all the labor and set up the ecu for you, then supply you with 3 different ecu programs. You then can try each program and use whichever one works best (changing chips is easy… no technical no how needed). and you can buy extra ecu chips for $11 each if you buy either their stage1 or stage 2 kit. check it out… its the best deal i’ve found on ecu’s yet.
