my temp gauge moves toward the hot side fast when i close my sun roof what could that be someone plz help
Thank you
Thank you
You have short circuit. I think you should not use Sunroof until repair the your cable.
As I though you have to make some operation the cables which are located behind of the Sunroof Button…
u can also check your battery ground to see if it’s making good ground contact…
You have a grounding issue. Make sure your engine is grounded.
