On a cold start up, my temperature gauge goes straight to the middle right when I start it. then tends to overheat when it gets warm (stays at 3/4 and fluctuates around there). Could it be air in the cooling system? Is the temp sending unit BAD and how can I test/tell? Need help plz
Test resistance of the sender when it’s cold. See if it falls within spec
