Tenzo R Racing Seats on DA?
How hard is it to install Tenzo R Type R Racing Seats on my DA? I do not have the rails for the Tenzo R seats, but i am planning to use the stock rails and modify it a bit. Also will my automatic seat belts be a problem? If anyone did this before plz help me. Thanks.
i have em in mine, but i made the mistake of getting red ones. they fade horribly, if you don’t have the seats already, i don’t suggest getting them. and i was going to modify my brackets too, but found that it was going to be way more work that i wanted to get into, so i bought some aftermarket ones. regular seatbelts might happen, but i didn’t even mess with it, i just bought some four point harnesses. but like i said, save yourself the money if you havne’t already bought em.
i just bought one for my friend yesterday and installed it.the only thing i dont like is the facory seat belt in the driver side always loose so im planning to get a 4pt harness,im still shopping for a good one but i dont know which one is the best and easy to install.do u know wat kind of harness will i get for a tenzo r seats on our da??
hehe i would like to know about that also. neone know?
i got some rci’s from prostreetonline.com
just so you are aware. if you do not hook up your 4 point harness correctly you are risking a broken back in an accident.
the straps that go over your shoulders need to be anchored to either a bar across the back seats at shoulder level. or over the bar and down to the floor.
if you just go right over the shoulders and down the back of the seat to the floor you set up a dynamic that will cause your spine to compress in a forward accident.
good to know, i’ve heard some things like that before, but not from reliable sources, thanks.
Can someone post pics of a setup with what hes talking about? I’ve seen some people mount the harnesses to the back seat bolts but I heard thats dangerous. Are we just SOL and have to fabricate our own harness bars because I haven’t found anyone that sells them for G2’s.
ok yesterday i took off my stock seats and took off the stock rail on them. there was no way the tenzo r seats will fit on the rail without modification. should i drill a new hole on it? also the seat belt part, do i have to saw it off for the seats to fit in? also do neone know wat i need to do with my seat belts. i do not want four point harness…thanks.
