So like a month ago my driver side window went down but never came back up and I finally pulled out the regulator and motor the regulator seems fine (as well as fuses) and I wanted to check if it was the motor, So do you guys know any way to check the motor? and also just to check… any ways to check the master switch.
Supply power and ground to the two terminals on the motor, it makes no diff. which way you do it, one way the window goes up the other way the window goes down. 94
