Good thing I saw it. Only got through the loom. Must have started a few years back when I removed the bracket that was holding the intake manifold, which in turn held the wire in place.
caught it just in time it seems!
Whoa! I should check mine.
If you’ve removed the intake support that normally supports that harness, then yeah check it. Otherwise it should be fine. I tie wrapped it to another harness but it had too much slack and sat on that bolt.
