The Alb and E-brake light...light on when driving
Just wondering if n e body would know what the problem is…my e brake and ALB light keep goin on when I start my car or when I’m driving…and my car still runs great.
What happens to be the problem…please help?
I belive the alb light will come on if you drive for so long with your e-brake handle up some. It could be a problem with the sensor switch at the e-brake handle.
Check your brake fluid my brother had that problem with the e brack turned out he was low on brake fluid
ALB light comes on automatically when you drive with the BRAKE light on, so lets concentrate on the BRAKE light as that is probably the “real” problem:
the Brake light will come on for one of two reasons:
  1. Brake Fluid low. Check the Brake fluid resovoir on the master cylinder unde the hood on the driver’s side of the firewall. Make sure the fluid level is OK. If it is, then disconnect the two cables that plug into the resovoir cap. If the light goes out, then you have a bad float switch on the cap.
  2. Ebrake not fully disengaged. Make sure ebrake lever is completely down (Sometimes stuff gets in there and keeps it from going down all the way). Take off the trim panel around the ebrake handle and check the little switch that is in there to make sure it is working properly.
One of these two should solve you problem
ARCHIVETHIS
