[QUOTE=fcm;2109199]Your amp gain, [INPUT SENSITIVIT (V)] is well below 50% and not your problem.
You need to switch the “Operation” switch from stereo to L+R.
Disconnect the “P.CON(REMOTE)”, blue lead/terminal and use a jumper from “POWER IN BATT” to "P.CON(REMOTE) to turn amp on, DO NOT leave connected, if amp still cuts out, amp control is not your problem.
I am concerned about the gauge of the power and ground leads, [10ga or less] it is a long way from the front of the car to the amp and “lack of” current may be the issue. 94[/QUOTE]
Left the INPUT SENSITIVIT as is.
Already switched to L+R.
bypassed the remote control and drove it for a week or two. There was a slight bass loss intermittenly. Meaning, slight bass loss happened twice out of the two weeks of bypassing the remote. The rest of the time, the system sounded great.
I went to trace the power and ground cables for any shorts only to find that the ground cable itself was very long coiled up in zip ties. The distance between the amp to the ground point is just 1.5 feet. But that cable was long. Should I shorten the ground cable or leave as is?
As I followed the the power and remote cables I noticed about three to four cable clamps scattered across the cables all the way to the HU. The clamps look similiar to the first pix. The two yellow ones top right from the amp. What were they doing? And I found a break or exposed copper on the power and remote wires smashed on the door floor panel. The routing was horrible. Will electrical tape fix the expose wire?
So my intermittent bass loss issue is still there. As you requested, I plan on changing out and reroute the power, ground, and remote wires when I have free time. And to change it to 8 ga wires.
