When you say “second” relay, you mean one of the two within the MFR? Have you taken apart the main fuel relay to see if the connections inside are good? When it takes time for the CEL to turn off and you’re able to start the car - is it consistently the same amount of time, or does it seem to be random? Sometimes taking a few moments and sometimes taking a long time?
No, the time is random, but starting high, over 2 minutes, then coming down to 30secs and lower after several starts untill it works properly if I continue to start it. but if I let it sit for even a miute then It will take up to 10 seconds to restart it. And that is my problem. I don’t know what is causeing the delay. I have 2 fpr’s and they both act the same…I even tried resoldering the small board on the fpr, but it reacts the same.
DO NOT get a new engine harness. This will make your problem worse. You want to use the original harness for the CHASSIS. The wiring in the connectors on the main harness are different for the GSR and rs/ls/gs models, so you need the main harness to match the engine harness or you’ll be routing signals to the wrong place. Of course you could re-pin the connectors - but in this case that’s pointless, you already have the right harness.
The EGR only came on auto trans cars, you have a manual trans, so you do not need to plug it in. I’m pretty positive you can just leave it unhooked. But it’s worth doing some searches about “deleting” or removing the EGR system. You could also look at the auto to manual trans write-up, as it will talk about the EGR system and what you can do with it when you install a manual transmission and manual ECU.
Read THIS thread. It will explain the various “units” you’re dealing with and how they change from 90-91 to 92+. It sounds like your engine is a 90-91. In which case you need to cut off the plug on your engine harness and extend the wires to the ECT switch. However, if you said the fans already go on, then someone may have already made it so the fans work properly. Go look at your thermostat housing, does it have an ECT switch on it? Or is it bare of anything with a wire connected to it? It’s possible that someone installed a 92+ thermostat housing with the ECT switch and then just plugged the engine harness in as it normally would on a 92+.
That must be it because there is not a switch on the rediator. There is a switch in the thermostat housing. And the fan cuts on normally
THIS is what a 92+ thermostat housing and ECT switch looks like.
Throw your Haynes in the trash! Or burn it! It’s complete crap and you’re completley wasting your time with it. it doesn’t have enough information and a lot of info is either missing or incorrect. The Helms is the only manual worth using.
I downloaded the service manual…much better and much more depth!can learn from this manual
Welfare is correct, that is your vtec wiring. Just leave it alone, it’s perfectly OK for it to be disconnected and will cause ZERO problems. I ran a car like that for YEARS. And as I stated before, only auto trans cars came w/ an EGR system. So yes, that’s why you don’t have that wiring.
Nice to know that part…so guess an incorrect intake manifold. will either block it or get one without the egr port.
As I stated before, do not use anything but the GSR engine harness. You’re asking for more trouble if you try swapping.
OK, so after all of this reading in both of your threads this actually sounds like an extremely easy problem to troubleshoot. And this troubleshooting starts at the main fuel relay and will lead to other wiring and the ecu. Follow the troubleshooting procedure beginning on 11-119 in the Helms manual. The procedure will guide you thru checking the main fuel relay, and all of the wiring involved in that system.
You have to remember that you seem to have some sort of temperamental and intermittent problem. The main fuel relay is known for such finicky problems. However if the problem was caused by an incorrect wiring harness you’d expect it to be a consistent problem…
I have 2 MfR’s, they both work, but both get a delayed energize signal from somewhere. I hope the guy can get much closer or figure it out for me…will let you know. Am keeping the orginal engine harness in for now. Thanks
OK, enough typing for now, I gotta eat dinner![/QUOTE]
