the driver side door handle and that little oval area that surrounds it is loose. Is there a screw on the inside of the door that i can tighten to make this not wiggle insanely as it does now?
There are 2 bolts in there. Take off your door panel to get @ it. It’s not hard, esepecially if you have a Haynes or other repair manual. You should have one anyway. A valuable tool. Come to think of it, if you had the manual, you wouldn’t be askin’ this question. Most of the posts on here can be answered by the manual and/or searchin’ hard. Hope all this helps.
:getsome: :manual:
yes it does help because now I know how to fix it and i am going to go get that manual you suggested! Good looking out!
