Things you need:
- medium sledge (~2lb hammer-- You need this to whack the hell outta the old LBJ so it comes out)
- snap ring pliers
- grease
- new LBJ from parts store.
Process:
1- Remove Hub/Knuckle assembly from car. DO NOT BREAK YOUR JOINTS, USE THE PROPER TOOLS. (Compact Pitman Tie Rod End Puller will seperate them safely)
2- Put the castle nut back onto the old LBJ, so you wont break the threads.
3- Remove the Snap ring with the Snap ring pliers. The snap ring is located on the under side of the LBJ, near the end of the boot.
4- Hammer the old LBJ out, UPWARDS. (NOTE: This will also force the metal ‘ring’ inside the knucle out as well. This can be hammered back in later)
5- Grease the walls of the LBJ hole LIGHTLY, and then WIPE THE GREASE BACK OFF.
6- Tap the new LBJ into place, from the Hardened top end. Be careful not to break the rubber boot, or flex the joint too much.
7- Install the new snap ring that should have been included with the new LBJ.
8- Reinstall that metal ring which popped off, onto the hub/knuckle, by carefully tapping it with a hammer back into place.
9- Reinstall Hub/Knuckle assembly back onto car. Take care when mounting the new LBJ back into the lower control arm. Tighten all parts to torque specs, and adjust the nuts to install the new cotter pins, and new spindle nut for the axle.
DONE!
Was that REALLY all that hard?
Articles/Teg Tips here I come!
