I got bored, and was looking at a bunch of hood pin types and install articles online.
As I know this is a frequently asked question for owners of carbon fiber hoods
I’d thought I’d list out the links for all of you. Enjoy! ![]()
<b>Manufacturor’s of hood pins:</b>
-Moroso
-Sparco
-Momo
-Mr. Gasket
-Longacre
-Rebco
<b>Types of Hood Pins:</b>
-Quick Release Slider Mechanism & Scuff Plate Combo (Screw On or Rivet)
-Notched, Pointed Threaded Rod
NOTE: Must use 6-8 a hood for safety.
-Straight Pin w/attached Loop
-Scuff Plate & Pin Guide Combo (Screw On or Rivet)
-Flattened Threaded Rod
-Cotter Pin
-Scuff Plate (Screw On or Rivet & May be Adhesive or Non-Adhesive Plate)
-Rounded Threaded Rod
-Cotter Pin
-Scuff Plate (Screw On or Rivet, Adhesive or Non-Adhesive)
-Lanyard Cables
-Locking (Requires Special Key) w/ Scuff Plate (Felt or Adhesive Scuff Plate?)
-Locking Threaded Rod
<b>Material Types:</b>
-Aluminum
-Anodized Aluminum
-Chrome Steel
<b>NOTE:</b> Scuff plates can be adhesive or non-adhesive. However, they are
usually applied with rivets or screws. Screws are recommended for steel hoods.
Rivets are recommended for fiberglass and carbon fiber. I’ve also noticed, that
some companies carry kits to recess the scuff plates even with a steel hood for
a finished look. Also, some kits come with a scuff plate backer plate, which
sandwiches the hood between these backer plates. Backer plates to
the scuff plates will probably be stronger. Some kits also come with locking
washers.
This kit comes with backer plates and locking washers:
http://www.dzstoys.com/images/pins/
http://www.irvansmith.com/catalog2/parts/hood_pins.shtml
http://moroso.com/catalog/categorydisplay.asp?catcode=23036
http://www.sparcousa.com/ptuning_accessories.asp?id=198
http://www.sparcousa.com/ptuning_accessories.asp?id=197
http://www.bakerprecision.com/hoodpin.htm
http://www.bakerprecision.com/longacr52.htm
http://www.rebcoperformance.com/catalog/catlist.asp?catid=17
http://www.cfiworld.com/autoparts/chrome/hoodpinkit/hoodpin.htm
http://www.alliancelink.com/users/joshsdodge/hoodpins.htm
http://www.miata.net/products/pmisc/sparco_hood_pins.html
http://www.metromotorsports.com/tiparchive/tipview.asp?TipID=13
