custom rear fog light
volt gauge/radio tray
your engine management software isnt going to incorporate a timer?
i havent heard of the need for a turbo timer on a honda since before sport compact car was taken off shelves.
[QUOTE=1ac4u2nv;2107516]Fog light air duct installed. I’ll be swapping between the duct and my regular fog from time to time.
What’s the point of the duct?
[QUOTE=db1st;2108415]custom rear fog light
how did u do the rear foglight…looks awesome:up:
simple…just cut and tap into the inner brake light and install a switch and remember to cut the right inner brake light so that it doesn’t look like u have a brake light out.
cool man did u install a brighter bulb in there or what…so it looks normal when u havent turned the switch on
nope…i used all the original parts i.e. bulb/socket wires…the inner brake light is a double filament bulb with both running lights/brake light. just tap into the brake light wire.
got ya man looks good man unique
^i had that done to my car a few years back. lol
but i just turned the bulb so the brighter filament stayed on. ghetto i know, but it worked. I dont do that anymore though, aha.
-karlo
I was routing hose to the intake but I ended up taking it off. I like my yellow fogs instead.
haha i love this shit… my car is so full of custom stuff as well ill take pics when its clean and show off the ghetto custom
more custom stuff!
gauge pod in front of shifter and cruise control in ash tray
vtec controller wired up under ash try to little knob and shift light in front of shifter
:rockon:
[QUOTE=jdmb16b;2111654]
:rockon:[/QUOTE]
Do you have any other close up photos? I started making a pod like that probably 5-6yrs ago and never ended up finishing It’s still in the garage and I was planning on using it eventually. Mine’s made out of fiberglass, yours looks maybe like plexi? Or maybe it’s fiberglass but painted gloss?
ahh i see a gsr badge! i need another one, some idiot jacked mine
97 JDM ITR Cluster
Wow, that looks perfect. What did you use to make the new bezel out of? I’m guessing both the DA and DC bezels and fiberglass?
fiber glass I belive. Ive always thought that cluster install came out spectacular:rockon:
[QUOTE=JDM1nt2B;2112032]97 JDM ITR Cluster
legit.
very nice, i like it
Thanks guys. I used the da bezel and chopped about an inch of the rear off. then did the same with the dc bezel and used that rear part. I used some everglass and duramix to bond the two bezels. I did that with the cluster installed and taped up, taped the dc bezel to the installed cluster, then installed the da bezel and once everything was properly aligned i bonded the two bezels.
