the window on the passenger side sits too high to fit under the rubber i have to close it by pushing on the window or leaving it down and rolling it up when the door is closed is there some kind of adjust ment screw? and there are deep scratches in it to like somthing dragging on it i had no problems untill one of my dumba$$ friends sat on the door when it was open and i had to adjust it could adjusting the door done this?
this thing is really startin to piss me PLEASE HELP
periods are a good thing.
try again…
the window on the passenger side door sits too high to fit under the rubber when all the way up. i have to close it by pushing on the window, or leaving it down and rolling it up once the door is closed. is there some kind of adjustment screw? and there are deep scratches in the window like somthing dragging on it i had no problems untill one of my dumba$$ friends sat on the door when it was open. i had to adjust it so it would close. could adjusting the door screwed up th way the door sits in the frame?
this thing is really startin to piss me off PLEASE HELP
sorry bout that
yes adjusting the door could make it sit wrong or crooked but if u adjust it right u would be fine. there is window adjustment nuts/bolts behind the door panel.
