Thermostat replacement
How the hell do I get this damn thing out?! I have the Helms in front of me…but do I really need to remove the all the hoses connected to the thermostat housing and then take the housing out then open it up to replace the thermostat? Im stumped on how to replace it since theres not much room to work with…help!!!
Thanh
Alright, I got one of the 2 bolts that hold the thermostat housing together…but I cant get to the bottom screw, I know its a beoch to get out so if anyone has any techniques to get it out…please do, thanks
Thanh
Nevermind, Im DONE!!! I had to take off my strut bar and intake pipe to get more room…a small 10mm socket did the trick along with some hand contortion…not bad at all.
Thanh
Hey Thanh, I will give you a tip… Call me next time and I will let you know what you need to do. Either that or you can come over and we can do it together.
Later,
BR
Yes sir! Id just figure it was a Friday night so u might be busy performing with the band so I just took it upon myself to figure it out.
Thanh
