i was wondering if these headlights are adjustable…this is actually my car so im not referring to buy them…this crap is shooting too low and its starting to piss me off…thanks g2ic( im pretty sure this has probably been answered before)
I don’t have the lights but did you check to see if the lights have adjusting screws like the OEM ones?
check out the back view
and you’ll see the round metal adjuster just to the *i mean left of the black headlight dust covers.
stick a screwdriver in the slot at the top and you turn it either way to adjust it.
^^ YUp that’s what I was referring too…
Tilegend - thanks for the pics… that should help out the guy. :rockon:
In that pic there should be 2 adjustor screws for each bulb minus the turn signal. One controls the up and down and the other adjust the left to right. On that one though I only see one for the left, gold colored, and one for the right, silver colored. Hope that helps. If you cant figure it out take it to a shop and it should not be more then maybe 20-30 bucks and they will dial it. Most places that do that will have a mark on the wall where light shouldnt go above to avoid blinding other drivers.
they are adjustable, I have a set, if you adjusted them properly, you’d have a good amount of light on the road, they arnt easy to adjust tho, you have to take em off turn the screws put em back on, see the difference, adjust again. repeat.
hope it works out for ya
Dave
thanks to all my gen2 brothers…ill do…
