i kno they are ebay brand but they are pretty clean. i wouldnt go to the track with them or anything like that but they look to be nice cruising rims (and they are fairly cheap i might add). :rockon:
I don’t know about those ebay rims… they might be heavy as fcuk. Just go with Rotas or Nippons if you want fairly cheap rims. A set of 15 Nippons will run you $280 picked up here in Cali and they are fairly light for DD wheels… just a suggestion.
i had nippon racing rims before, they are light 14.8lb, and looks just like te37 with 0 offset
they are really good rims, i totaled my da, the car was hit on the rim , it didnt crack, just a lil bent , i didnt believe its bent untill i was swapping the tires tried to balance
i had mine for 310 picked up , the other colors are cheaper like 280
wheels tires and brakes are the only place that i would never skimp on.
with that said, i would never buy an off brand part to replace an important OEM part.
dont skimp on your safety. you never know when an inconsistency in the forging/mold process will create a stress crack and blow your wheel up on the freeway at 70+mph
