do you guys think it will work. i’m thinking of rewiring the cluster from the rsx to a da. (exam: taking the rsx cluster apart and removing the tach, gas, oil, and speedometer and replacing it inside the DA’s cluster…)
now do you think it will work or ??? what type of problems do you think i would run into? i have a friend who’s selling his cluster and i don’t think it would be a bad idea to do it… i think it would look bad ass.
yea i was thinking about the difference in the whole system…
do you think i can detach the dials off each part of the meter’s and have them adjust to the da’s. (probably won’t even have to rewire anything, maybe it’ll be plug and play) idk, i’ll test a few things and see i can get it to work… the only thing i can probably think about changing out if it does work would be the dash lighting (if it didn’t get bright enough, probably try and change it so it’ll be bright enough to light up the whole dash parts…)
hummm…idk… i’ve got to talk to a friend of mines to see if how much he’ll let his cluster go.
