I boogered up my tie rod thread. Does anyone know the size? TIA.
Tie rod or radius rod? The radius rod “end” is 12mm x 1.25. The tie rod is 10mm x 1.25. Hope this helps.
Dan, I am not very knowledgeable about my suspension. There is a castle nut on the piece I am referring to. Thanks for your reply.
The radius rod has no castle nut on it, the tie rod does, it’s the ends of your steering rack that attach to the knuckle/hub assembly. Those are 10mmx1.25
