i just wanted to know if anyone has had experience with diagnosing the tdc sensor. I am really dreading having to replace the distributor and kinda hoping that its something less expensive.
I just replaced the iacv with a “good” one this is the third iacv i have replaced with the same results.
how can i test the iacv? I have already jumped the connectors and heard a click on all three. But I still get a code 14.
Oh and i forgot to mention the cel is not on. These codes are stored in the ecu and i have reset it several times.
Well i opened up my distributor today and its full of brown dust and everything inside looks like it has been under water for a year. All the bolts to the cap were tight, and I don’t see any cracks.
Now i’m waiting for the pb to loosen up the rust holding the rotor button on, hope the coil is still good.
Only one code down? i thought 7 through 9 were distributor sensors, either way good job on clearing up that one. I had an CEL 8 and i took the sensors from a td-44u ( civic sohc ) Distributor and swapped all the sensors and wiring into my old distributor, all i had to do was splice one wire for the coil. If you need any help i have a few pics of it (loki9_5@hotmail.com)
