Hey,
I was about to take off my throttle body to clean it, But I was thinking could I just clean with it on, and take some of the hoses off and spray cleaner in the holes and then lift the butterfly up and spray into the intake manifold???
Any body have any suggestions or Ideas
thanks
TB
you should take it off, there is no gasket between the TB and the intake manifold so you do need to worry about that, and you dont want to get stuff in your engine, dont want to screw anything up if you can avoid it, so i would suggest taking it off
Re: TB
actually thre is a gasket between the two…
