Throttle cable help
I have a 92 gsr with a b18c1 swap, im doing an engine build on the b18c1 and i purchased a blox racing manifold and tb, but now the throttle cable does not work. I’m not 100% sure what cable was on it originally, but with the manifold and tb meant for a b18c1, would i use a gsr throttle cable or a different one?
I think you need the itr p73 throttle cable and cable bracket.
www.inlinefour.com has the set cheap.
You can rig up the stock stuff to work correctly… I’m using my stock bracket and cable on an ITR manifold and aftermarket TB.
