any idea how to setup the throttle cable properly with a gsr head and a skunk2 intake manifold? what throttle cable bracket, throttle cable, and throttle rotor do i use? im using a stock gsr throttle body
you will need the gsr throttle cable and bracket to make it work with no problems. other than that Fabricate!!! :ohyeah:
yea i figured i’d have to do some fabbing of some sort. thanks
You can redrill the old LS bracket. Measure the distance center to center off of the Skunk2 and mark on the old bracket and drill a new hole.
