tightening throttle cable?
I remember there was a post either in here or bseries that showed how to tighten the throttle cable. anyone here know how to do it? Please advise…thanks.:dead:
two 12 mm nuts before the throttle body on throttle cable . loosen them and tighten cable , but leave a little slack so idle doesn’t change. if you have access to a scantool watch tps % while you tighten it and it should stay at 0 % if you show anything but 0% it was tightened to much.
Just get under your hood you’ll figure it out it’s pretty easy.
