Timing belt? 100k or 60K clarification
How often do we change out our timing belts on a daily driver? Searched “timing belt” and went through all ten pages.
My guess is 100k?
Helms says replace every 90k miles. I would replace it if the water pump leaks coolant.
Also, valve clearance should be checked every 15k miles or about once a year. Good time to inspect the T-belt.
It’s best to change it a little earlier, than a little late.
I had one break at 140,000km and it wasn’t pretty - bent most of the intake valves, had to get a tow, $$$ + inconvienence.
my family has had a few hondas. with good care and regular maintenance your t-belt can be safely replaced at 150k mile intervals, if youre a bit more vivacious with your right foot, and/or you get fluids on the belt, id say change it earlier.
some of the local honda guys i know say 90k with higher performing motors, esp higher RPM applications
[QUOTE=OMG Its Weasel;2082819]with good care and regular maintenance your t-belt can be safely replaced at 150k mile intervals[/QUOTE]I’ve usually gone 130K miles on mine w/ no problem but I like to get my money’s worth. If you go by the 2001 Integra maint. sched. it says 105K miles and it uses the same exact parts, shouldn’t be a difference in the interval.
One thing that has not yet been discused is time between T Belt change as apposed to mileage. The manual recommends that the t belt be replaced at 90k miles or 10 years which ever comes first. The rubber and nylon in the belts degrades over time and can fail at less than 90 miles if the car is older.
i would change it sooner in FL just because it constantly in the heat , ill do my wifes on her d17a2 at 75k miles and i will do the water pump anyway just because !
on the older acura/hondas it used to be 80-90K the newere cars they say 105K or every 7 years
