Timing Belt finally done!!!!
Well thanks to the help of the members on this board and a few phone calls to Dan, I was able to get my rounded tensioner pulley bolt out. New timing belt is on and I have to say my car hasn’t felt this good in a LONG time. So, once again I would like to thank everyone who helped me out with this project.
Jeff
Just out of curiosity, how did you get the rounded bolt out?
I used a dremel witha a 90 degree elbow, but it was to wide to go straight down on the bolt. So using fiber glass blades I cut at the middle for awhile and used a grinder in there and finally I watched the washer fall. I bpuller the pulley off and unthreaded the bolt by hand.
Jeff
Originally posted by mosier
[B]I used a dremel witha a 90 degree elbow, but it was to wide to go straight down on the bolt. So using fiber glass blades I cut at the middle for awhile and used a grinder in there and finally I watched the washer fall. I bpuller the pulley off and unthreaded the bolt by hand.
Jeff [/B]
huh im not sure what you mean. i resorted to welding on a bigger nut and that did the trick. had to remove the motor mounts to lower the block and get access to it through the firewall
I cut the head of the bolt off. I slid the pulley off the bolt and then unthreaded it with my hand. Why did you go through the firewall?
