Timing Belt Question
I’ve tried searching, but no luck. I have the B17A motor and I already have the b18c gsr timing belt, tensioner, and water pump. I’m wondering if I can just go ahead and use that for the b17a motor since the timing belt is due for a replacement. Thanks for any info.
I would suggest getting on oriellys website and search timing belt for a 94 GSR and a 92 GSR. If the part # is the same then your good.
I just did the water pump on my teg and i would sugest to get the parts for a b17 my car was stuck for 3 days because of the wrong water pump. I have heard in theory it should work because the space from the cams to the crank is the same. I would get parts from a B18 a or b because of the smaller water pump gear so it will spin faster than the GSR pump that has a huge gear.
