how do i get the timing belts to stop making so much noise. i spray wd-40 on the pulleys it only stops it for a couple of seconds and comes back agin. do i need a new set of belts?
thanks
I think your talking about your power steering belt right? Well either the belt hhas gone bad, or you need to get rid of some slack.
WD40 isn’t a good thing to spray on belts because it will just make them slip more.
If your belts aren’t already screwed, get some belt dressing that will help them stick to the pulleys. And tighten your belts.
thanks guys
