TIMING....confused with red & white lines
I tried to adjust the timing like it said in the teg tips.
I’m confused with the lines.
I tried to line up the red line to the marker but the dist. won’t turn anymore.
I had the timing gun saying 18.
At 18 the white line is at the marker &
at ZERO the red line is at the marker.
Is this correct???
The mechanic friend I borrowed the gun from said that’s how it should be.
From what I understand in the teg tips though, the red line should be at the marker while the timing light is at 18.
When I turned the dist. till it can’t turn anymore, the red lines up with the marker & the timing light/gun says 7.
Does anybody know how it actually is?
The car runs fine that’s why I don’t know if it’s right or wrong.
Thanks.
Use the white line.
thatz what the manual says.
I guess it is correct?
When the white line is lined up with the marker & the timing light says 18?
Then when you set the timing light to zero the red line is at the marker.
Thanks.
I believe the white line is 18 and the red line is 16. Do it on the white line.
HTH
Ken
…yeah, doing the white line is some good $hit…
:wink:
Oz
http://www.c-speedracing.com/howto/timing/timing.html
Has the info you need.
