I just swaped a B20 in my 90 Teg…now I originally thought that the 98 B20’s
distributor would work fine with my exsisting wiring harness, if I spliced it in correctly with the proper wire schematics. I was VERY WRONG!! The ECU will not register it…I should of guessed that but I tried anyway. So I pulled it and put the original distro. off of my B18 and re-spliced the wiring. My problem is how do I get the timing set up? I know how to set and adjust timing on applications that have already been in place, but this is slightly different figuring that I just slapped the distro. in there. ANY TIP’S???
WOW!!! 51 views and no input…does anyone have a clue to give me a hand?
umm try and post in the correct forum next time and you’ll get more help?
This forum, in which you posted in:
“Articles / Teg Tips™ (2 Viewing)
Articles pertaining to G2 Integras and DIY Teg Tips.
DO NOT POST NEW HELP THREADS HERE. DO NOT POST SCANNED COPYRIGHTED MATERIAL.”
is NOT for help threads.
moved from Articles/Teg Tips to High-Tech, Hybrids & Aftermarket Engine Performance
http://www.g2ic.com/tegtips/engine/7.html
Start with the distributor in the middle of the adjustment range.
